PHANTEKS PH-CB-CMBO BL 19.68" 24 PIN - 8PIN - 4 PLUS 4 M - B, 8PIN - 6 PLUS 2 PCI-E EXTENSION CABLE KIT 500MM LENGTH
Phanteks PH-CB-CMBO_BL 19.68" 24 Pin/ 8pin (4+4) M/B, 8pin (6+2) PCI-E Extension Cable Kit 500mm Length Type: Extension Cables Color: Blue Specifications: Conductive Resistance: 0.01 ohm Max\x0D\x0A\x0D\x0AType: 24 Pin/ 8pin (4+4) M/B, 8pin (6+2) PCI-E Extension Cable Kit\x0D\x0A\x0D\x0ASleeve Tube: PP Material\x0D\x0A\x0D\x0AConnector: \x0D\x0A24 (2x12) Pin/Male to 24 (2x12) Pin/Female\x0D\x0A4(2x2)+4(2x2)/Male to 8(2x4)Pin/Female \x0D\x0A2(2x1)+6(2x3)/Male to 8(2x4)Pin/Female\x0D\x0A\x0D\x0AConstruction AWG: 18AWG, \xC3\x982.1mm (Rohs) \x0D\x0A\x0D\x0ACable Length: 19.68" (500mm)\x0D\x0A\x0D\x0APackage Dimension: 1.50" x 6.00" x 11.50"\x0D\x0A\x0D\x0AWeight: 0.88 lb.
Price: 29.99
