PHANTEKS PH-CB-CMBO GR 19.68" 24 PIN - 8PIN - 4 PLUS 4 M - B, 8PIN - 6 PLUS 2 PCI-E EXTENSION CABLE KIT 500MM LENGTH
Phanteks PH-CB-CMBO_GR 19.68" 24 Pin/ 8pin (4+4) M/B, 8pin (6+2) PCI-E Extension Cable Kit 500mm Length Type: Extension Cables Color: Green Specifications: Conductive Resistance: 0.01 ohm Max Type: 24 Pin/ 8pin (4+4) M/B, 8pin (6+2) PCI-E Extension Cable Kit Sleeve Tube: PP Material Connector: 24 (2x12) Pin/Male to 24 (2x12) Pin/Female 4(2x2)+4(2x2)/Male to 8(2x4)Pin/Female 2(2x1)+6(2x3)/Male to 8(2x4)Pin/Female Construction AWG: 18AWG, Ø2.1mm (Rohs) Cable Length: 19.68" (500mm) Package Dimension: 1.50" x 6.00" x 11.50" Weight: 0.88 lb.
Price: 34.99
